Hard starting
170,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
COGGY76
It does not like to start once it is at running temperature, starts but, seems to need fuel. When it is cold it fires right up. I changed the fuel filter but the problem is still there. When running it runs great, checked with an obd reader no codes come up. Help
Oct 30, 2018 at 3:09 AM
Good afternoon.
I would start by checking the actual fuel pressure. You need to check it when the engine will not start. It sounds like a failed fuel pump.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Oct 30, 2018 at 4:37 AM
