Engine will not stay running
180,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
DERWIN TAYLOR
Car only runs for twenty seconds.
Dec 8, 2018 at 9:00 AM
  • 110,248 POSTS
When it stalls, does is start right back up? Has the check engine light come on? If it does not restart, have you checked for spark and fuel to the engine?
It sounds like a few possible things. However, my first suspect is a bad crankshaft position sensor. Here are a few links to look through. However, the first one I listed is related to a bad crankshaft position sensor symptoms. To determine if the sensor is bad, check to see if the plugs are getting spark when the engine won't start. See link 2
Link 3 discusses general causes for engine stall.
Also, a weak fuel pump can also be an issue. See link 4.
https://www.2carpros.com/articles/stall-at-idle
The fuel pressure specs are as follow:
Fuel System Pressure
Key On Engine Off 52-59 psi
Let me know if any of this helps or if you have other questions.
Dec 8, 2018 at 1:00 PM
