Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
4Runner
Engine
Symptoms
Not Running
Engine not starting
1998 TOYOTA 4RUNNER
36,000 MILES • 4 CYL • 2WD • AUTOMATIC
LANNY HILLHOUSE
MEMBER
1 POST
Put new fuel pump in and not starting.
Jan 15, 2021 at 11:22 AM
Experienced Mechanic
This sounds like a fuel pump or the fuel pump relay has gone out. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Jan 16, 2021 at 7:00 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
