Engine not starting
36,000 MILES • 4 CYL • 2WD • AUTOMATIC
LANNY HILLHOUSE
Put new fuel pump in and not starting.
Jan 15, 2021 at 11:22 AM
  • 55,710 POSTS
This sounds like a fuel pump or the fuel pump relay has gone out. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Jan 16, 2021 at 7:00 AM
