fuel
130,000 MILES
THREELEGS
Car won't start, will turn over. I checked the fuel rail no gas.hecked fuses all good. Does this mean the fuel pump is bad or is there anything I can do before I pull the pump? Also is their and access panel under the seat?
May 10, 2013 at 1:51 AM
SATURNTECH9
  • 30,869 POSTS
No access panel understeer seat you have to drop the exhaust and gas tank to replace the pump.I would Check for power and ground to the fuel while cranking.There is a inline connector under the car by the gas tank you check it there.you can also trying cranking it while hitting the center of the gas tank with the palm of your hand and see if it starts.also is the security light on solid or flashing while trying to start it?
May 10, 2013 at 11:20 AM
