Good morning,
This is a code for the engine running too cold.
the most common reason for this is the thermostat stuck open. I would start by replacing the thermostat.
Do this first as this effects fuel mapping and may take care of the issue with running.
SYMPTOM
P1281 - ENGINE IS COLD TOO LONG
TEST NOTE
This symptom is diagnosed using the test P0125 - CLOSED LOOP TEMPERATURE NOT REACHED.
WHEN MONITORED
The ignition key on, engine running.
SET CONDITION
The engine does not warm to 176 °F while driving for 20 minutes after start.
POSSIBLE CAUSES
- Low coolant level
- Thermostat
- ECT sensor (out of calibration/high resistance in related circuit)
Dec 18, 2018 at 8:53 PM
