fuel
1967 ALL OTHER MAKES ALL OTHER MODELS
200,000 MILES • 6 CYL
KAREYWOODS
  • 5 POSTS
Starts and idles ok but when you push the gas pedal the engine dies
Feb 5, 2016 at 11:38 AM
CJ MEDEVAC
  • 11,000 POSTS
OK
WHACHU GOT?
GIMME THE WHOLE STORY/ WHAT'S BEEN DONE/ LAST TIME IT RAN RIGHT/ ETC. THE MORE INFO YOU PROVIDE, THE BETTER
THE MEDIC
Feb 5, 2016 at 12:22 PM
KAREYWOODS
  • 5 POSTS
Just bought the car
Feb 5, 2016 at 12:47 PM
KAREYWOODS
  • 5 POSTS
I cant seem to get the answer
Feb 5, 2016 at 12:56 PM
  • 31,937 POSTS
We need to know what type of car and what engine and if any codes are logged if fuel injected, more info please.
Feb 5, 2016 at 3:58 PM
KAREYWOODS
  • 5 POSTS
1967 american rambler 6 cylinder
Feb 8, 2016 at 6:01 AM
CJ MEDEVAC
  • 11,000 POSTS
OK
YOU MOST LIKELY HAVE A 232 CU IN ENGINE
PRETTY MUCH THE SAME THING AS THE AMC 258
THIS IS GOOD NEWS FOR YOU, IMMA JEEP GUY, MY '77 JEEP CJ-5 HAS A 258!
I ANSWER MANY OF THE JEEP QUESTIONS THAT COME THRU HERE, I HAVE MANY PICS W/ EXPLANATIONS THAT I POST TO AID IN FIXIN' THE CJs, THEY MIGHT HELP YOU TOO.
I NEED SOME INFO, TELL ME WHAT I'M SORTA UP AGAINST, LAST TIME IT RAN, DOES IT HAVE POINTS OR AN ELECTRONIC IGNITION SYSTEM?
IS THE FUEL TANK DECENT/ BEEN SITTING FOREVER WITH NASTIFIED FUEL IN IT?
DO YOU HAVE A VOLTMETER?
ARE YOU SORTA AUTO MECHANICAL?
WHAT HAS BEEN DONE?
MANY JEEP POSTS I ANSWER ARE OVER A HUNDRED RESPONSES LONG (NOT TO MENTION MONTHS LONG), MEANING, AS LONG AS YOU ANSWER AND PROVIDE INFO FROM YOUR END, I'LL CONTINUE TO HANG WITH YOU!
THE MEDIC
Feb 8, 2016 at 7:56 AM
KAREYWOODS
  • 5 POSTS
Not mechanical it has a distributor so i think it has points it has been sitting for a while maybe 2 or 3 years i havent looked at the gas but it starts up and idles pretty good i mean it dont stop running but as soon as you push the gas pedal it dies and i do not have a volt meter
Feb 12, 2016 at 8:34 AM
CJ MEDEVAC
  • 11,000 POSTS
WELL, IDLES IS A GOOD THING!
I BELIEVE I'D DROP THE TANK AND EMPTY/ CLEAN IT.
THREE YEARS IS A LONG TIME FOR A CARB TO SIT WITH STALE/ NOW VARNISH FUEL INSIDE IT. REBUILD OR REPLACEMENT IS WHAT SHOULD HAPPEN TO MR. CARB
MOST LIKELY THESE ARE "GIVENS" THAT SHOULD BE ADDRESSED FIRST
ONCE THESE ARE NO LONGER BAD FACTORS , EVERYTHING MIGHT GO JUST FINE!
IF NOT, WE CAN CONTINUE WORKING ON OTHER PROBLEMS
YOU NEED TO VERIFY WHETHER YOU HAVE A 232 OR A 199 INLINE SIX CYLINDER.
JUST FOR GIGGLES, I LOOKED UP A CARB FOR THE 232
IT'S AN ORDER ITEM ONLY
-IT HAS A $36 CORE, WHICH YOU WILL GET BACK IF YOU TURN THE OLD ONE IN TO THE STORE
http://shop.advanceautoparts.com/p/autoline-remanufactured-carburetor-c7000/20122919-P?searchTerm=carburetors
IF YOU HAVE THE 199, LOOK UP IT'S CARB ON THAT SITE
LET'S MAKE THIS EVEN BETTER- LETS SAVE ANOTHER $40 ON THIS ORDER!
"TRT41" PROMO CODE WILL KNOCK OF $40, SO THE ORDER WILL BE $199.99 + $36 CORE -MINUS $40 PROMO. THE ORDER WILL BE $195.99. WHEN YOU TURN THE CORE IN, YOU WILL HAVE ACTUALLY SPENT ONLY $159.99! SHIPPING IS FREE!
EVEN THOUGH THIS IS A ONLINE ORDER ONLY, OTHER STUFF YOU NEED CAN BE OBTAINED IN A SIMILAR MANNER, BUT PICKED UP AT THE STORE IN 30 MINUTES! SEE HOW THIS WORKS IN THIS LINK
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
KEEP RESPONDING, WE WILL KEEP GOING!
THE MEDIC
Feb 12, 2016 at 9:29 AM
