Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-350
Tires
Symptoms
Shake
front wheels
2004 FORD F-350
800,000 MILES • 4WD
RICHARD LENNOX
MEMBER
Shakes over 50 miles an hour.
May 12, 2016 at 7:17 AM
HMAC300
Experienced Mechanic
check the tires for balance first then check u-joints on drive-shaft and center support bearing on drive-shaft if you have one.
May 12, 2016 at 9:16 AM
RICHARD LENNOX
MEMBER
Thank you so much
May 12, 2016 at 10:48 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
