What is the proper procedure and torque values for installing/tightening the front wheel spindle nuts?
246,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
NIGHTHAWK4570
  • 24 POSTS
Front wheel spindle nut torquing procedure/values needed.
Mar 25, 2023 at 6:48 PM
  • 55,691 POSTS
Do you mean the rotor to spindle nut? If so, here are the instructions in the diagrams below. Please let us know if you need anything else to get the problem fixed.
Mar 26, 2023 at 12:00 PM
NIGHTHAWK4570
  • 24 POSTS
Yes, the rotor to spindle nut was what I was referring to. Thank you. An automotive shop told me that the front wheel bearings needed repacking which is why I needed to know the torque specifications.
The shop also told me that the right front inner tie rod has excessive play and that the rack and pinion needs to be replaced due to fluid leakage. A Ford/Motorcraft remanufactured rack and pinion is costly, and I've heard nothing but bad as to aftermarket brands. I can purchase a used rack and pinion from a local used auto parts supplier for $100 that comes with a 90-day warranty. What would your opinion be on this and is there any safety concerns I should have if I was to install a used rack and pinion?
Apr 2, 2023 at 3:31 PM
  • 55,691 POSTS
Yes, I would only go with a rebuilder that stands behind there work for 1 year. The rest are cheap and you will be replacing it again. If you need more help please start a new question. Please post your new question here, you must be logged in.
Cheers, Ken
Apr 3, 2023 at 4:07 AM
