front wheel hub replacement
246,000 MILES
STEVE49
I am trying to change the front wheel hubs on my 2000 Chrysler Intrepid. The after market parts and the O.M.E .parts do not fit. The original parts that I removed have a 1/4 inch collar on them and the O.M.E.and after market parts have about 3/4 inch collar. The receiver for the wheel hub assembly has only enough room for the 1/4 inch collar. I have gone to the dealer with the VIN number for the car and they tell me that the parts they have should fit. Is there some extra parts that I need to make these other parts fit?
May 25, 2013 at 6:10 AM
DOCFIXIT
  • 18,828 POSTS
Intrepid is a Dodge is this a Canidian made car?
May 25, 2013 at 6:22 AM
STEVE49
According to the ownership and the door panels, it is a Chrysler.
May 25, 2013 at 6:35 AM
STEVE49
And as far as I know it is Canadian made. If it wasn`t you would think the dealer would have let me know.
May 25, 2013 at 6:37 AM
DOCFIXIT
  • 18,828 POSTS
Part will be different see if you can get the Temkin # off old bearing. Asume live in USA?
May 26, 2013 at 4:38 AM
DOCFIXIT
  • 18,828 POSTS
Go to NAPA with bearing there are two the Canidian bearing is different they should be able to match Timkin #
May 26, 2013 at 4:50 AM
