front wheel bearing problem
2014 RENAULT
71,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
DAVIDMTHEMBU
my Duster needs a front wheel bearing replacing. the dimensions of a bearing are OD80 mm- ID42 mm- WIDTH39 mm.
my local auto spares only have -WIDTH38mm.
will one mm make a big difference? can i use a 38mm?
Feb 7, 2017 at 3:46 PM
STEVE W.
  • 15,421 POSTS
No you need the correct bearing. The narrower one will be loose in the bore and will not pre-load properly when tightened down.
The correct bearing is a MAPCO- 26151 or A.B.S.- 201402 or SKF- VKBA 6682 or FEBI BILSTEIN- 33988
This place claims to have them.
https://www.sparepartstore24.co.uk/renault-spares/duster-2011/57797/10679/wheel-bearing
Feb 7, 2017 at 7:42 PM
