Hello, when replacing front wheel bearing, does the ABS sensor have to be replaced with a new one, or can the original be used?
Mar 21, 2022 at 9:23 PM
BORIS K
✓Experienced Mechanic
The ABS sensor should be reusable with the new wheel bearing.
A problem could occur when trying to remove the old ABS sensor from the housing. These usually get stuck, corrosion, and when trying to remove the sensor they usually get damaged.
