Front wheel bearing replacement
2003 HONDA JAZZ
119,000 MILES • 1.3L • 2WD • AUTOMATIC
LIBBY300
  • 21 POSTS
Hello, when replacing front wheel bearing, does the ABS sensor have to be replaced with a new one, or can the original be used?
Mar 21, 2022 at 9:23 PM
BORIS K
  • 836 POSTS
The ABS sensor should be reusable with the new wheel bearing.
A problem could occur when trying to remove the old ABS sensor from the housing. These usually get stuck, corrosion, and when trying to remove the sensor they usually get damaged.
How to replace an ABS sensor.
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
How to remove a broken sensor.
https://youtu.be/KvjYoK_lo5g
Please let us know how you get along.
Cheers, Boris
Mar 21, 2022 at 10:08 PM
