Front wheel
123,000 MILES
HABS6669RBNB
  • 13 POSTS
There is a slight vibration with front passenger side wheel vibration is not present in steering wheel only when sitting in passenger seat.Rim and tire balance is right on checked all tie rods outer and inner there is no play at all ball joints are good also there are new sway bars and bushings.Could it be cv or bearings ?
Apr 17, 2013 at 8:51 AM
could be but i would look closer at the tires
Apr 17, 2013 at 9:04 AM
HABS6669RBNB
  • 13 POSTS
I have looked closer at the tires i even switched the two front tires around and the vibration still is on passenger side of vehicle.
Apr 17, 2013 at 9:32 AM
yes, it could be the axle causing this vibration if all the others have been checked
Apr 17, 2013 at 10:06 AM
