Front washer fluid will not come thru wiper squirters but works on rear wiper
50,577 MILES • 2.4L • 4 CYL • AWD • AUTOMATIC
SLASH3233
Front washer fluid will not come thru wiper squirters but works on rear wiper. All rubber pipes are connected and I could not see any leaking fluid around area. Rear wipers and front wipers work I can get fluid squirting in rear, just not the front
Mar 24, 2014 at 4:42 AM
HMAC300
  • 48,601 POSTS
disconnect squirter hose and see if fluid come through like that if it does then use a very thin wire down the squirter and then hook hose back up and try it should work. if no fluid going in hose replace squirter motor
Mar 24, 2014 at 11:49 PM
