Front vents working intermittently
81,500 MILES • 5.7L • V8 • 4WD • AUTOMATIC
SHAWNAK75
My condenser went out in my air conditioner. Had it replaced and shortly after front vents stopped working some of the time. After diagnostic, we replaced the blower motor and fuse but all front vents still only work intermittently.
May 1, 2022 at 9:58 AM
  • 55,554 POSTS
When the vents are not working can you still hear the blower motor running? If so, it sounds like a blend door actuator is not working. If not, it sounds like the blower motor relay needs to be replaced here is the location and a guide to help test the relay.
May 2, 2022 at 10:10 AM
