Front turn signals/Hazards
84,000 MILES • 4 CYL • MANUAL
JAMISON GARZAREK
1987 Mazda B2000 front turn signals or flashers won’t work but the rear ones do (flashers and turn signals). Also noticed left turn indicator on dash sometimes stays lit. Bulbs are good
Mar 10, 2018 at 12:52 PM
KHLOW2008
  • 41,812 POSTS
Do the rear turn signals blink at a very fast rate or as normal ? For the front signals, do they just light up or nothing at all? If they don't light up at all, the problem should be due to a broken link in the wiring. You need a test light to check if power is getting to the bulbs. If none, then you have to back trace the wiring for fault, to the flasher relay.
Mar 12, 2018 at 1:50 AM
