Front suspension noise and shake
126,000 MILES • 4 CYL • 4WD • AUTOMATIC
GEORGEBUSE
I think I have to replace the struts and motor mounts. What would be the cost?
Apr 29, 2019 at 12:46 PM
  • 110,251 POSTS
Welcome to 2CarPros.
The first three pics show parts and labor for struts. Note the labor is indicated in hours, so you need to know the hourly rate of the shop you take it to. As far as the parts, the prices are for original equipment parts and often times aftermarket parts are less expensive.
Interestingly, they provide labor for one strut or both. It is always recommended that both be replaced at the same time. Additionally, you should have the vehicle aligned after the struts are installed so add approximately another $100.00. Please note that the original wheel size does make a difference on part cost.
_________________________
I did the same with engine mounts. See pictures 4 and 5.
Apr 29, 2019 at 1:18 PM
