If you are removing the strut assembly, you will need a universal puller. See the last pic below. If you don't have one, most parts stores will lend one to you.
The remaining pics are the directions/steps to remove and replace the strut assembly. Here is a link you may find helpful as well. It explains in general how it's done. The pics are more understandable. LOL
Let me know if this helps or if you have questions.
Images (Click to make bigger)
SPONSORED LINKS
Tuesday, August 30th, 2022 AT 7:44 PM
CADY1
MEMBER
2011 CADILLAC CTS
3.6L
6 CYL
4WD
AUTOMATIC
100,000 MILES
Torque specifications. Front strut assembly, control arms, tie rods and anything else you could think of that would involve bushings.
Thanks, Tony
Thursday, September 1st, 2022 AT 10:45 AM
(Merged)
MECHANIC
If you look at pic 1 below, it shows the specs for the front suspension components. Note that it indicates shock to. And not strut.
Take care and God Bless,
Image (Click to make bigger)
(Merged)
DANNY L
MECHANIC
Hello again.
Here is the information you requested. I've attached the torque specifications for the front strut assembly, lower control arms, and the inner and outer tie rod ends you mentioned. Let us know if you need any further information or diagrams. Hope this helps and thanks again for using 2CarPros.
Danny-
(Merged)
CADY1
MEMBER
2011 CADILLAC CTS
3.6L
6 CYL
4WD
AUTOMATIC
90,000 MILES
Need info including torque specs to remove the strut and coil spring assembly on my vehicle which includes partial disassembly of the front control arms as well
Thanks
Tony
SPONSORED LINKS
(Merged)
MECHANIC
Take a look at the attachments below. They include the torque specifications for replacing the strut assembly.
Let me know if everything is there that you need. If there is something additional, let me know.
(Merged)
