This need needs a front suspension. will a Dodge Stratus or Intrepid fit and be compatible to be put into a Dodge Neon?
Sep 25, 2019 at 2:58 AM
DANNY L
✓Experienced Mechanic
Hello, I'm Danny.
Quick question first. What suspension component are you looking to change?
Thanks for using 2CarPros.
Danny-
Sep 25, 2019 at 7:35 AM
LCUNNINGHAM4369
MEMBER
Control arm or spindle on right passenger side.
Sep 25, 2019 at 11:58 PM
DANNY L
Hello again.
No, unfortunately none of those components are interchangeable. You can only use those suspension components from a Neon only.You might want to try find a wrecking yard/dismantler in your area to save money. Those components can be purchased at your local auto parts stores.Hope this helps and thanks again for using 2CarPros.
