Front struts
137,265 MILES • V8 • 4WD • AUTOMATIC
RAIDERMIKE
I have a Z55 Autoride suspension. If I replace the front with a conversion kit - replaces electronic design shock with passive design. Includes sensors to bypass shock control. Will it effect the rear struts if they are still electric?
Jul 14, 2018 at 3:40 AM
  • 110,248 POSTS
That is a really good question since the vehicle suspension is reading front to rear all the time. I feel it is may be okay; however, the vehicle's stability control may be affected. If the aftermarket manufacturer does not require you to replace all four, you should be okay. I am not exactly how the sensors you are using will bypass or eliminate the need for height issues, but I feel confident that if they made them, it should be fine.
Jul 15, 2018 at 1:23 PM
