Front struts replace the struts or not?
237,012 MILES • V6 • 2WD • AUTOMATIC
T. JOHN
  • 25 POSTS
Before i ask my questions. A little overview. I bought the vehicle listed above sr5 v6, 9 years ago, today 9-09-2015. It had about 110,000 on it. Fast forward to today. 9-9-2024. It now has 237,121 on it. The front struts/shocks are at least 9 years old and good chance older than that. I found out a week ago the rack and pinion needs to be replaced on it. shocks are good. The struts have been for about a year leaking a little bit and still about the same today. In your view if you were me would you replace the struts or not? My thinking if i say still have the 4runner say well over a year from now. Sooner or later, they will have to be replaced. What would your view on this be?
Sep 9, 2024 at 5:20 AM
  • 55,732 POSTS
Yep, I would replace the front struts with over 110,000 on them and they are leaking. Here is the correct way to replace them, also make sure you get a high-quality part because there are plenty of cheap ones that fail prematurely. I would get the replacements with the coil spring it is easier and much safer. Check out the images (below). Let us know if you need anything else.
Sep 9, 2024 at 8:37 AM
T. JOHN
  • 25 POSTS
Thank you for your fast reply and Indepth response in how to replace them.
Sep 9, 2024 at 9:07 AM
  • 55,732 POSTS
Our pleasure, let us know how it is going or if you need any more help.
Sep 10, 2024 at 2:13 AM
