Front right wheel winding sound with acceleration
100,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
ROCKERDUDE56
As speed increases front right wheel has winding sound that goes fast or slow with speed.
Mar 8, 2018 at 1:41 AM
Good afternoon.
There is a hub bearing at the wheel that supports the axles assembly. it is a common failure for this noise.
It is not serviceable and if bad needs to be replaced. The brake dust from the brakes gets into the bearing and causes the failure.
Mar 8, 2018 at 3:23 AM
ROCKERDUDE56
The hub bearing is replaceable by removing large nut on wheel?
Mar 8, 2018 at 7:12 AM
That is correct. The wheel needs to be removed.
the brake caliper and rotor need to be removed.
The axle nut needs to be removed
The ABS connector needs to be released
The three attaching bolts need to be removed.
The hub assembly can be removed.
Mar 8, 2018 at 8:14 AM
ROCKERDUDE56
Thanks Roy.
Mar 8, 2018 at 8:11 PM
You are welcome.
Mar 9, 2018 at 2:07 AM
