Front RH (Passenger) Fender Liner - Splash Shield Missing
140,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
B767_400
  • 36 POSTS
Was just replacing the Harmonic Balancer.
During disassembly I discovered that a Splash Shield is missing from the Fender Liner which is protecting the Balancer from debris and water coming from the tires inside the wheel well.
I can see that there are two holes where the Splash Shield seems to be attached to the Fender Liner.
Could anyone let me know which PN the Splash Shield has and if it is still available somewhere?
Thanks
Aug 13, 2025 at 7:55 PM
MECHTRIX
  • 599 POSTS
I assume your talking about the one in the righ hand wheel well right ? You can try a wrecking yard near you or theres a bunch of wrecking yards online now too that can send it right to your doorstep .
Aug 14, 2025 at 8:44 AM
MECHTRIX
  • 599 POSTS
Heres the part number for the passenger side splash guard 22659114..good luck
Aug 14, 2025 at 8:48 AM
B767_400
  • 36 POSTS
Just to be sure, there is just one piece of fender liner which also covers the Silencer.
So in my case someone brke off a part of it, it is not a separate item, correct?
Aug 14, 2025 at 9:09 AM
MECHTRIX
  • 599 POSTS
I think there's two different parts I believe the fender liners plastic right ? And the part that covers the silencer should be a metalic part to shield heat ...
Aug 14, 2025 at 9:32 AM
MECHTRIX
  • 599 POSTS
Yep " Metal for exhuast pipes and usually plastic for inner fender wheel well /mud guard type parts or splash shields
Aug 14, 2025 at 9:36 AM
MECHTRIX
  • 599 POSTS
There a seporate metal exhuast manifold shield for that right behind the plastic fender well slpash shield
Aug 14, 2025 at 9:54 AM
MECHTRIX
  • 599 POSTS
it shows 4 different shields for your exhuast up front and some near the wheel well they all mount in the same general area so can you post a photo of the wheel well in mind and the area of the exhuast youre asking about ?
Aug 14, 2025 at 9:56 AM
B767_400
  • 36 POSTS
Might it be this one:
Splash Shield - GM (22636582)
Will try to make a Photo.
Aug 14, 2025 at 9:59 PM
MECHTRIX
  • 599 POSTS
Gm 22636582 yep thats it.
Aug 15, 2025 at 1:27 AM
MECHTRIX
  • 599 POSTS
There 3 other part number for that same part but use that one its the updated part number ..its the right side in the chart its number 12.. good luck
Aug 15, 2025 at 1:29 AM
B767_400
  • 36 POSTS
Just to double check.
Does it fit my 3.1 V6 because the accompanied text only states 4 cylinders.
Aug 15, 2025 at 7:22 AM
MECHTRIX
  • 599 POSTS
Yes anytime you get a part whoever you order it from will double check to make sure it
S the correct fitment for you year model ..but yes it does seem to be the right part for your car but since it shows that it also fits other cars definately double check when you go to order it and if youre buying it on line they always use a tool to check if its correct anyway before you buy it same as any dealership doea you can also call most any chevy dealers parts department and they can just look it up for you hope this helps good luck.
Aug 15, 2025 at 7:58 AM
MECHTRIX
  • 599 POSTS
Yeah now that you have a part numbe Id call a dealerships parts department give him the i formation about your car and they can most likely look it up to comfirm and let you know what it might cost aslo rock auto.coms pretty good also parts geek has a surch tool thats good and they both have fair prices ..best of luck .
Aug 15, 2025 at 8:23 AM
B767_400
  • 36 POSTS
Have an issue now .... part is discontinued and cannot find it Online
In addition, I would need to find a company willing to ship Overseas to Europe.
Any ideas whom I could contact?
Aug 18, 2025 at 6:48 AM
MECHTRIX
  • 599 POSTS
I dont know of any off hand but you can try to google automotive wrecking yards that ship internationally ..and see what comes up i didnt know you needed it over there thats far away ...but good luck hope this helps .
Aug 18, 2025 at 7:23 AM
