front passenger side wheel locking up at random
279,000 MILES • 1.7L • 4 CYL • TURBO • 2WD • MANUAL
JUDDUU22
When ive been travelling for a while there is a small juddering on the wheel then it will lock up as if the brakes have been applied but just on that side.
Jul 12, 2014 at 12:18 AM
CARADIODOC
  • 34,416 POSTS
Next time this happens, open the bleeder screw on that caliper, then see if the brake releases. If it does not, suspect the caliper. If it does release, the brake fluid is being trapped and can't flow back to the master cylinder freely. Do the test again by loosening the steel line at the master cylinder. You're looking for the first place the fluid pressure releases.
Jul 12, 2014 at 1:54 PM
