Front passenger door rattle while closing with window down
11,360 MILES • 1.2L • 3 CYL • 2WD • MANUAL
BHASKARBHAT
I recently noticed some metallic sound, like metal items brushing each other while closing the door. The noise comes up only when window glass is down. Typically, I keep my windows closed and hence did not notice this previously. Planning to take it service center in coming week. I am grateful for any inputs on this issue. I wanted to have some insight before heading to the VW authorized service.
I am from Bangalore, India and the car is under warranty. Also, any insights on how this issue occurs and is there anything that I need to be mindful about?
Thanks in advance!
Apr 14, 2018 at 6:23 PM
HARRY P
  • 2,292 POSTS
It is probably something simple, like a loose bolt. There is not much that you can do to keep it from happening, other than make sure that the nuts and bolts are properly tightened, using lock washers as necessary. Hopefully the guys at the dealership know what they are doing well enough to use washers so this does not happen again.
Apr 14, 2018 at 8:41 PM
BHASKARBHAT
Thank you very much, just checked with a friend of mine he feels it should not be too big of an issue. Will respond post the visit to VW service center.
Apr 14, 2018 at 11:29 PM
  • 55,721 POSTS
Please do. We are interested to see what it is.
Cheers, Ken
Apr 18, 2018 at 4:56 AM
STEVE W.
  • 15,413 POSTS
These days there are a lot of things inside the doors. It could be anything from a loose fastener, cable guide rubbing, window track that is loose or?
Let us know what they find.
Apr 18, 2018 at 5:34 AM
BHASKARBHAT
Hi All, sorry had not logged into the site in a while. The issue was a minor one, just a loose bolt that caused the issue. The Authorized Service guys fixed it without any hassles. It has been a few months and no noise. So far power window, electronically controlled mirror, child sensor in for the window glass, one pinch up/down all work fine too.
Sep 29, 2018 at 2:13 PM
DANNY L
  • 5,648 POSTS
Glad to hear all is well!
Thanks for using 2CarPros.
Danny-
Sep 29, 2018 at 2:46 PM
HARRY P
  • 2,292 POSTS
I am glad it was something simple. Thanks for checking back in and keeping us posted. Please come back any time.
Sep 29, 2018 at 8:38 PM
