How to remove front passenger seat manual recline handle?
130,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
TTAYLOR0127
How do you replace the passenger outboard with a manual seat recline handle.
Feb 16, 2021 at 7:41 AM
Just to be clear, you want to replace the power seat with a manual seat? If that is the case, you may be able get this to work by removing the motor, switch, reclining mechanism. Then installing the manual lever assembly in its place but it would be far easier and cheaper in the long run to just find a manual seat from a salvage yard and swap it in.
Here is the process from the manual on how to replace the seat.
Is there a reason that you want to convert it over? I suspect it is not working but would want to try and fix it or do you know what the issue is with it?
Feb 17, 2021 at 10:35 AM
TTAYLOR0127
No, I'm not replacing the seat. Just the outboard on the passenger seat. I cannot figure out how to remove the manual recline handle in order to remove the old outboard.
Feb 17, 2021 at 7:26 PM
Can you get a picture of what you are trying to remove? I attached the process from the manual on the reclining handle if that is what you need. Otherwise seeing it will help because we may be calling it different things.
Feb 18, 2021 at 8:41 AM
