I recently installed all new brake pads and rotors. While replacing them I needed a new left rear caliper. So put everything together and bled the system started from wheel furthest away from master cylinder. Then went for a test drive. Notice a dragging brake noise on the front left. So, I replaced the caliper and went for a test drive. Same problem. Replaced master cylinder and brake line and still same problem with brake not releasing.
Sep 13, 2023 at 1:30 AM
