Front headlight assembly right and left
81,921 MILES • 3.6L • 6 CYL • AWD • AUTOMATIC
BOSAIM
both of the headlights have a fog or a coating over the inside of the lens causing the
illumination to be less than acceptable as I was turned down for an inspection sticker
Is there a way to clean the lensese without having to replace the entire assembly as three different
dealers want between 1200.00 - 1300.00 to replace them
Your answer will be appreciated
Jan 8, 2014 at 12:57 AM
HMAC300
  • 48,601 POSTS
try a junkyard, it may be hazed or fogged because of putting a brighter bulb in the headlight causing more heat.schram auto parts in Michigan is a large GM parts place of used ones.
Jan 8, 2014 at 1:32 AM
