Front grinding noise
72,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
7MASHBURN
As I pull out of driveway turning right I get a grump grump grump grump left front. After I straighten out for a few feet it quits and never heat it again until it is parked for a bit. Can’t seem to make it do it after it quits until it sits for awhile. Old rotors were bad. wife got hard on brakes and the shaking tripped the ABS T/C and stabitrac light and the noise started. So I change the brakes and rotors still have the noise. AutoZone cleared the light and as I was leaving heard the noise lights came on and went into limp mode but quickly came out and drove like normal. Not sure now maybe wheel bearing or CV axle.
Nov 19, 2019 at 9:48 PM
What were the codes when they cleared them? This sounds like the ABS is activating. If that is the case, I would suspect the wheel speed sensor has an issue but the code will help determine what the issue is.
Nov 20, 2019 at 9:42 AM
