Front end work wobbly when hitting bumps?
4.6L • AUTOMATIC
NORTHSTAR1137
I have a 1999 Lincoln town car I have changed the upper ball joint and inner and outer tie rod ends on the driver side and now it squeals when you turn some what and is wobbly when hitting bumps, what did I do wrong ?
Oct 14, 2026 at 11:31 PM
MECHTRIX
  • 583 POSTS
Sounds like maybe its out of alignment and also the wobbling can be caused by a few things like worn pivot point bushings/joints of several types and everything in between like a broken shock right down to just a unbalanced wheel (vary comon) i cant say it enough its always a great idea to get it up on a lift with the wheels and suspention unsprung and wheels free and get a good look at it but yeah id check those two things first alighnment and wheel balance good luck hope this helps
Oct 15, 2026 at 8:04 PM
