The front end starts to vibrate when going over 50 MPH?
264,635 MILES • 3.0L • 4 CYL • 2WD • AUTOMATIC
RONALD DEVOLD
  • 134 POSTS
I replaced the CV axles with an aftermarket part. My question is, is the that the cause and should I install OEM Mazda part?
Mar 4, 2023 at 12:32 AM
  • 55,688 POSTS
If the vibration stops if you let off the throttle, and then comes back when you try to accelerate the CV axles will be the problem. If not I would get the tires balanced and while you are there check to see if you have tire treads that are separating. Please let us know.
Mar 4, 2023 at 3:40 AM
