Front end vibration
134,934 MILES • 4 CYL • FWD
CMZANNN
  • 84 POSTS
On the freeway last night all the sudden the front end started to vibrate at sixty five mph. when I backed off it stopped the struts need to be replaced because when cutting wheels the clack clack is present. also, I bought two used tires for front Sunday because others threadbare I noticed when leaving shop, passenger side felt out of round. it drove smooth until last night. I was able to get freeway speed by slowly accelerating. should I focus on tire rotation putting fronts in back rear tires are in real good shape. due to fixed income and unforeseen expenses this month I need to fix this myself which is why I came to the very best. You two have always helped me money or not in a timely fashion straight help, no BS. you are the very best on the web or anywhere. thanking you in advance.
Jan 12, 2017 at 10:51 PM
LOU P
  • 118 POSTS
Hello, Lou here, if the problem did not occur until the tire replacement then the first thing I would check is make sure the lug nuts are tight, just to be certain. next I would rotate to the rear to see if the issue persists, that would give me without a doubt a reason to suspect the used tires. either a belt slipped or a wheel weight came loose , hope this helps, Lou.
Jan 12, 2017 at 11:03 PM
CMZANNN
  • 84 POSTS
Thanx Lou I did move tires and regulate air pressure .helped tremendously the car seemed to ride smooth.noticed some bouncing..like a stiff suspension
Jan 15, 2017 at 4:30 AM
CMZANNN
  • 84 POSTS
Also Lou when I rotated tires and regulating air pressure I noticed a slight imperfection on the rim edge could that be causing bouncing?
Jan 15, 2017 at 4:42 AM
  • 55,746 POSTS
Not really, I am thinking it will be a problem with the front CV axles, here is a guide to help you replace the parts. Also check the lower ball joints.
https://www.2carpros.com/articles/replace-cv-axle
Please let me know what happens so it will help others.
Best, Ken
Jan 18, 2017 at 5:28 PM
LOU P
  • 118 POSTS
In my opinion it depends on how big the imperfection is , if the rim is bent enough the tire will actually conform to the bend and wear more in that area and cause a wobble that can be felt when driving very slowly through a flat parking lot , you can feel the car shimmy side to side . But at least you know the issue is due to the tires. I would get a new set as soon as you can as you can have a slipped belt as well .
Jan 18, 2017 at 6:32 PM
  • 55,746 POSTS
good call Lou :)
Jan 18, 2017 at 10:16 PM
LOU P
  • 118 POSTS
Appreciate that Ken , cmzann please let us know the outcome :)
Jan 18, 2017 at 11:48 PM
