Front end rattle and vibration
78,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
PM213
Hi - Love this site, thanks for all you do!
So, about 8 months ago, (about 60,000 miles) I switched from 2 to 4 wheel drive and heard a loud pop when starting to back up. I did a quick visual inspection (loose anything, fluid drips) before proceeding. All looked well, so I backed up the 40' off-road (with a bed full of tools) without further issue. 60 minutes later, when back on pavement, switched back into 2 wheel, no problem, and went on home.
This was the last time I've engaged or disengaged 4 wheel drive.
Approximately 3 months later, started hearing a ticking noise that sounded like a wheel hub going bad (rate of tic increased and decreased with speed). Found a great deal on new parts so I replaced:
Hubs, rotors, pads, tie-rod ends, sway bar links, upper control arms and lower ball joints - both sides. Tires are about 1 year old at this point. Admittedly, I've not gotten a proper alignment since the front end work, but it wasn't much off and I'm a professional procrastinator... hey, it is what it is.
Ticking noise was gone..... for about 30 days, then returned. Has been progressively worsening, until its more like a grinding. About 2 months ago, it got dramatically louder. I crawled underneath & discovered 2 holes in the transfer case housing. I made contoured plates as patches, pop riveted in place and sealed around them with 'quick steel'. I have no idea if there is supposed to be fluid in the T-fer assembly, but since there was no evidence of any, I didn't put anything in.
Grinding noise has continued, of course, though not worsening. No loss in power, acceleration, etc. Over the past 3-4 months, a "wub-wub-wub" sound has joined the choir.
2 weeks ago, it suddenly developed a nasty vibration, and I was nervous to go above 40 mph. I drove it twice, less than 2 miles each trip and on the last outing, the rear propeller shaft bolts sheared from the rear differential. No real damage done, so I reconnected and replaced the U-joint.
All noises and vibrations remain, I still won't go above 40 - but now it pulls to the left rather dramatically and has difficulty getting to speed. Like I'm pulling some real weight.
I don't have the cash to take it somewhere, I don't know where one problem stops and the next one begins. Hoping for a starting place at least because I'm ready to light a match and watch her burn. I love/hate my Dakota!
Thanks, truly!
Michael - Indy
Apr 10, 2020 at 11:27 PM
Good morning,
Yes, the transfer case requires fluid. The fact you have driven it without fluid for the long time tells me the case is now no good. The noise you heard in the beginning was the issue where it was damaged.
You will need to replace the transfer case.
REMOVAL
1. Shift transfer case into 2WD.
2. Raise vehicle.
3. Drain transfer case lubricant.
4. Support transmission with jack stand.
5. Remove rear crossmember and skid plate, if equipped.
6. Disconnect front and rear propeller shafts at transfer case.
7. Disconnect transfer case shift motor and mode sensor wire connectors (4).
8. Disconnect transfer case vent hose (2) from the transfer case (3).
9. Support transfer case with transmission jack.
10. Secure transfer case to jack with chains.
11. Remove nuts (3) attaching transfer case (2) to transmission (1).
12. Pull transfer case and jack rearward to disengage transfer case.
13. Remove transfer case from under vehicle.
Apr 11, 2020 at 12:19 AM
PM213
Thanks. it sounds like I have my work cut out for me. I'll be sure to update if/when I complete the work.
Apr 11, 2020 at 10:45 AM
You are welcome.
Always glad to help.
Apr 11, 2020 at 10:46 AM
