I cannot find that spec.
a shop that puts it on an alignment machine will get the specs for you as they are built into the program for the alignment.
below are the basic specs.
FRONT:
With Standard Suspension:
Caster:
Range .................... +6.0° to +8.0°
Camber:
Range .................... 0° to -0.5°
Toe In (Each Wheel):
Preferred .................... +0.125°
Range .................... 0° to +0.25°
Toe Differential Left to Right .................... 0.5°
With Up-Country Suspension:
Caster:
Range .................... +5.5° to +7.5°
Camber:
REAR:
Camber .................... 0° to -0.5°
Thrust Angle .................... ± 0.25°
Total Toe-In .................... 0° to +0.5°
Apr 10, 2018 at 10:29 PM
