Front end noise
105,206 MILES • 1.6L • V6 • 4WD • AUTOMATIC
ALEXISGARRETT
  • 6 POSTS
My engine is making a noise it’s like coins in a jar type of noise and I’ve checked the transmission fluid and the engine oil and they both are fine. I took it to the shop and I thought it was something with the brakes but that doesn’t make sense because it’s when I could start the car not when I push on the brakes, any ideas on what it could be?
Jul 5, 2019 at 9:09 AM
Hi Alexis,
Unfortunately, I am not sure what this could be. Can you give a little more detail on when it does this or better yet, get a recording of the noise and post it here. That may help us get on the same page. Thanks
Jul 5, 2019 at 9:43 AM
ALEXISGARRETT
  • 6 POSTS
Sadly on a cold start the sound would be much louder, but this isn’t it on a cold start. It is the kind of higher ringing you can hear.
Jul 5, 2019 at 9:49 AM
Unfortunately I can't make it out to well. but does it make the noise if you take the serpentine belt off and start the engine?
Jul 5, 2019 at 9:52 AM
ALEXISGARRETT
  • 6 POSTS
I do not have the tools to do that and wouldn’t want to do it myself in fear of breaking something. I’ll give it a cold start in the morning so you can hear the sound more.
Jul 5, 2019 at 9:54 AM
ALEXISGARRETT
  • 6 POSTS
Here we go I got a good sound of it.
Jul 5, 2019 at 10:11 AM
Okay. That is better. I would have the belt removed and see if it does it. That sounds like a bearing to me. The other thing you can do is spray some WD40 on the pulleys as they are spinning and see if it quiets down. This will indicate a pulley is failing and the noise is the metal on metal of the bearing.
Jul 5, 2019 at 10:13 AM
ALEXISGARRETT
  • 6 POSTS
Okay, I’ll see what I can do.
Jul 5, 2019 at 10:36 AM
ALEXISGARRETT
  • 6 POSTS
It was the A/C compressor for future reference.
Jul 18, 2019 at 2:01 AM
Great info. Thanks for the feedback. Glad you got it figured out. Thanks for using 2CarPros.
Jul 18, 2019 at 12:50 PM
