Why is a sound rubbing from left front driver side wheel?
Dec 19, 2016 at 7:21 AM
HMAC300
✓Experienced Mechanic
it can be a lot of things but really you need a mechanic to hear this. it can be a bad wheel bearing, brakes and or brake backing plate hitting rotor and or rust caught between the rotor and backing plate. it cold also be an axle shaft making the noise as it is four wheel drive.
