Front end bouncing after installing 2" leveling kit
2015 GMC SIERRA
53,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
NATE222
Driving down the road getting over forty mph the front end starts bouncing. Faster I go the more the bouncing gets worse? Am i in need of alignment?
Dec 30, 2018 at 2:52 AM
  • 110,240 POSTS
First, make sure everything is tight and put together correctly. You have changed the factory Z height adjustments, so the alignment needs checked and adjusted. However, that shouldn't cause the bouncing. Shocks control the bouncing.
Have the alignment checked and adjusted. If that doesn't help, the only thing left is shocks.
Dec 30, 2018 at 7:41 AM
NATE222
Thanks. I'll go through everything again.
Dec 30, 2018 at 7:58 AM
  • 110,240 POSTS
Happy to help. I wish I had a better answer, but if it is "bouncing" the only thing I can think of is shocks.
Let me know what you find.
Dec 30, 2018 at 2:55 PM
NATE222
Fixed the problem! Haha feel like an idiot. So when I had the truck in my shop putting in the leveling kit, all the snow melted which the snow an ice settled on my inside of rear wheel wells. Which froze when I parked it outside. Causing the wheel to be out of balance in the rear. Chipped it all out and BAM! No vibrations.
Dec 31, 2018 at 1:15 AM
  • 110,240 POSTS
OMG! That makes so much sense. Tires were totally out of balance. Wow, I'm glad you got it figured it out and fixed. When you were saying bouncing, all I could picture was a shock not connected. LOL
Regardless, great job. Let me know if you have questions in the future, and I wish you and your family a Happy New Year.
Dec 31, 2018 at 8:22 AM
