Front end bounce when hitting small bumps
140,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
JOHN DANSON
When driving at low speeds like 30-40 MPH and hitting a small bump in road at times I feel the front end bouncing. I also can feel it in the steering wheel. But once a brake and slow way down it goes away and drives normal. I live on gravel and have checked the wheels for build up of gravel dust. It also doesn't appear to have any missing wheel weights. Could this be ball joints, shocks, or what? Any information would be appreciated!
Mar 5, 2021 at 7:15 AM
  • 110,248 POSTS
Try this simple test. Bounce the front of the vehicle. When you stop bouncing it, it should stop within 3 bounces. If it doesn't, the shocks are bad. Things like ball joints won't cause it to bounce.
If you find they are bad (and it sounds like they are), here are directions for replacement.
First, here is a link that shows in general how it is done:
https://www.2carpros.com/articles/replace-shock-absorber
Here are the directions specific to your truck for replacement. The pics below correlate with the directions.
_________________________________
2003 Ford Truck F 250 2WD Super Duty V8-5.4L SOHC VIN L
Front
Vehicle Steering and Suspension Suspension Suspension Strut / Shock Absorber Service and Repair Procedures Shock Absorber Front
FRONT
Shock Absorber-F-250, F-350, Excursion
Removal
WARNING: All vehicles are equipped with gas-pressurized shock absorbers which will extend unassisted. Do not apply heat or flame to the shock absorbers during removal or component servicing.
CAUTION: Suspension fasteners are critical parts because they affect performance of vital components and systems and their failure can result in major service expense. They must be replaced with the same part number or an equivalent part if replacement is necessary. Do not use a replacement part of lesser quality or substitute design. Torque values must be used as specified during reassembly to ensure proper retention of these parts.
pic 1
1. Raise the hood and remove the upper shock absorber retaining nut and upper shock absorber insulator.
2. Raise and support the vehicle.
pic 2
3. Remove the lower shock absorber retaining nut and remove the shock absorber
Installation
pic 3
pic 4
1. Using new fasteners, follow the removal procedure in reverse order.
__________________________________
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Mar 5, 2021 at 4:04 PM
