Front end noise
222,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
JACOB COLLIE
I have replaced the inner and outer tie rods, the wheel bearing hub and the CV axles and it is still making a sound; like you are driving and hit the wake up line on the side of the road. i don't know what else it could be. I know that it stops if you make a righthand turn. What is it?
Dec 3, 2020 at 4:05 AM
Good afternoon,
I posted a picture for you of the dust shield that goes behind the disc rotor. Make sure this shield is not rubbing against the rotor while moving.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
If it is, you can just bend it back away from the rotor.
Dec 3, 2020 at 4:20 AM
JACOB COLLIE
Yes sir, I did that already. it is making a hitting noise like a wake up line on the side of the road if you know what I mean.
Dec 3, 2020 at 4:35 AM
Can you upload a video so I can hear the noise?
Dec 3, 2020 at 4:44 AM
STEVE W.
  • 15,419 POSTS
Is it the constant rumble with vibration or only the sound? As a test have you rotated the tires from front/back? A broken belt or odd tread wear can cause some strange noises.
Dec 3, 2020 at 4:55 AM
