Front end pull?
280,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
KEVIN DIAMOND
Had a slight pull to the left, had work done then alignment, everything is tight now and good alignment, but now the pull is a little worse, the shop had it again for 4 hours and couldn’t figure it out what is causing.
Sep 16, 2025 at 12:35 AM
CARADIODOC
  • 34,411 POSTS
Step 1: Switch the two front tires side-to-side, then test-drive it.
If the pull is still there, did you get a printout of the alignment? If you got one that shows the "Before" and "After" readings post a photo of that and I'll interpret the results.
I always put a copy of the printout on the passenger's front seat, with the items I adjusted or changed highlighted. My alignment computers deleted that information as soon as the next job was started. Today, a lot of the newer alignment computers keep the results in memory, so if you didn't get a copy, stop in and ask if they can still print one out for you.
Sep 16, 2025 at 1:54 AM
