Front driver side area
200,000 MILES • 4WD
YOTE TSOSIE
The tire wobbles .. An there is a grinding noise heard whn driving .. Unable to locate the noise .. The bearings are stil good. The brake pads are not good .. They are wearing diagonally instead of flat along line of surface. A video of the tire was takin but on another phone. We hav had an individual try to help ... But we are stil unable to get it fixed.
Apr 5, 2017 at 2:53 AM
CARADIODOC
  • 34,415 POSTS
If the pad wear you see is more on the "leading edge", meaning the end a spot on the rotor contacts first, don't worry about that unless it's excessive. That type of wear is common.
For the wobble, if it is bad enough to see, suspect that wheel is bent. Swap it one of the others to see if the wobble moves with the wheel. If it's still the left front, check for rust or debris that flaked off and got caught between the wheel and brake rotor. If you have the rotor design that slides off the hub, check behind that too for impacted rust or scale.
To verify the wobble, you can use a dial indicator to measure the amount of "lateral run out". Harbor Freight Tools has an inexpensive dial indicator. If you find more than about 0.035" of run out on the lip of the wheel, remove it and check the run out on the edge of the rotor. There you should find very close to 0.00" run out.
Apr 5, 2017 at 12:41 PM
