front driver caliper and rear right passenger caliper locking up?
114,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
CAF33085
Hello, lately it has been giving me braking issues. My front driver's side wheels lock up. I replaced the hose and caliper with new ones hoping that would fix the issue. When I put everything back together, and bled the caliper it locked up again. I took it upon myself to check the other tires making sure they're all good. To my amazement, the rear right passenger side wheel is also locking up along with the newly installed driver side caliper and hose. I bled the rear caliper, and it released the pressure making all the wheels spin, however when I applied brakes, the rear and front would lock up again. This is frustrating so any type of help or wisdom would be greatly appreciated at this point.
Feb 1, 2025 at 8:30 PM
  • 55,658 POSTS
No problem, hits happens when the ABS control module needs to be repacked, here is the location and how to do the job, also this guide can help as well:
https://www.2carpros.com/articles/a-comprehensive-guide-to-fixing-automotive-brakes-locking-up
Check out the images (below). Let us know if you need anything else.
Feb 2, 2025 at 2:53 AM
