lock front right tire up when pressing brakes
1996 FORD TAURUS
180,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
WINNARGA
  • 5 POSTS
Was getting brake pad sticking/seizing on driver front disc brake. Replaced brake caliper as caliper bushing was shot and thought piston was sticking. Replaced brake line from master cylinder to caliper as there was no indication of pressure at bleed screw but was from metal line at top of rubber hose. Now vehicle has no pressure and can lock front right tire up when pressing brakes hard enough but driver front continues to role. What is wrong!? I have spent $100.00 already trying to figure this out. :(
Aug 31, 2018 at 5:56 AM
  • 110,241 POSTS
Based on your description, it sounds like the master cylinder may be bad. This unit is a tandem master cylinder. The primary (rear) circuit feeds right front and left rear brakes. The secondary circuit (front) feeds left front and right rear brakes. What I need you to check is if the if the right rear brake is working. It sounds like the secondary circuit of the master cylinder may have failed. Check to see if there is pressure to the right rear brake. If there is not, replace the master cylinder.
I attached the directions for removal and replacement of the master cylinder in case you need them. They are specific to your car. All attached pictures correlate with these directions. The link below contains general directions for replacement of the master cylinder. It also explains how to bench bleed the new master cylinder before install.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
_________________________________________
CAUTION: Brake fluid will damage electrical connections and painted surfaces. Use shop cloths, drip pans and fender covers to prevent brake fluid from contacting these areas.
1. Apply the brake pedal several times to exhaust all vacuum in the system.
2. Remove brake tubes from primary and secondary outlet ports of brake master cylinder. Cover the ends of the lines to prevent dirt from entering system.
3. Disconnect fluid level indicator switch connector.
4. Remove nut retaining cowl top inner panel tube to brake master cylinder.
5. Disconnect cowl top inner panel tube from cowl and remove.
6. Remove two nuts retaining brake master cylinder to power brake booster assembly.
Master Cylinder
7. Slide brake master cylinder forward and upward from vehicle.
INSTALLATION
1. Before installing the master cylinder, check the distance from the outer end of the booster assembly push rod to the face of the brake booster assembly.
Master Cylinder
i 2. Position brake master cylinder assembly on studs on power brake booster assembly.
3. Install mounting nuts. Tighten to 26-39 Nm (19-28 lb ft).
4. Connect cowl top inner panel tube to cowl.
5. Install nut retaining cowl top inner panel tube to brake master cylinder and tighten to 21-29 Nm (16-21 ft lb).
6. Install primary and secondary brake tubes to brake master cylinder outlet ports. Tighten to 16-20 Nm (12-15 ft lb).
7. Connect brake warning indicator switch connector.
8. Fill master cylinder with DOT 3 brake fluid to MAX line on side of reservoir.
9. Bleed the master cylinder. Refer to Brake Bleeding.
10. Perform system brake bleeding procedures.
11. Operate brakes several times; then check for external hydraulic leaks.
I hope this helps. Let me know if this is the issue.
Apr 5, 2021 at 5:29 AM
WINNARGA
  • 5 POSTS
I jacked the passenger rear of the vehicle up so I could test your secondary circuit theory. I was able to spin the tire and stop it by applying the brakes. Does this mean that it is not bad?
  • 55,399 POSTS
The master is separated from front to rear. Do both front brakes act the same or just one side? If it is just one side the problem will be the caliper/flex hose. Does this car have ABS?
WINNARGA
  • 5 POSTS
It does not seem to have ABS. When starting the car there is no indicator lamp suggesting the presence of this type of system. The passenger front brake locks up often because it is the only one working in the front. As noted before, both the caliper and the hydraulic hose (aka flex hose) have both been replaced with brand new parts. At first I thought it to be the caliper because the caliper boot was no longer seated and there was visible rust on the caliper piston. Then I changed the flex hose for fear of a collapsed hose impeding fluid flow. Neither have worked and now the brake pedal travels almost to the floor before engaging the passenger right front brake only even after checking the hard lines for blockage before I replace the master cylinder.
  • 55,399 POSTS
This car can have ABS, can you lift the hood and look for the ABS controller (all brake lines will run into it will a motor and controller)?
WINNARGA
  • 5 POSTS
There is no ABS. The four lines cone from the master cylinder and connect to two different cross-shaped units (brake proportioning valves?). From there they travel to flex hoses and the brakes. Can the proportioning valves go bad for one wheel/brake?
  • 55,399 POSTS
Nope they are front and rear. When the problem happens can you loosen the master cylinder mounting bolts so the master can move way from the booster 1/4 inch to see if the problem goes away if so the booster push rod is adjusted too far out.
WINNARGA
  • 5 POSTS
There is no problem that happens at this point. The brakes are squishy and only engage the right front (passenger) brake. The brake pedal travels almost all the way to the floor before engaging. If I drive it and apply the brakes the car pulls hard to the right. I will try what you suggest though.
  • 55,399 POSTS
It sounds like a caliper slide is sized. Can you confirm both caliper can move freely?
