Front drive unit swap
148,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
GEARBAG1
  • 5 POSTS
Need to know how new a can go to swap out the front drive unit on my truck that still uses the vacuum pulse actuators for the four wheel drive?
Jul 18, 2018 at 12:25 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Just a quick question first. Are you asking what model years are interchangeable for your front differential?
Danny-
Jul 19, 2018 at 6:15 AM
GEARBAG1
  • 5 POSTS
To swap out the hole front differential and all. Cannot find the pulse vacuum actuators for my 1999. Why does the driver side have a nut on the end of the shaft and the other one just a spline?
Jul 19, 2018 at 7:32 AM
DANNY L
  • 5,648 POSTS
Hello again.
I called the Ford dealership and they would need the Ford P/N (part number) that is stamped on the Actuator. Can you upload a picture of the part and part number for me? Hope this helps and thanks again for using 2CarPros.
Danny-
Jul 20, 2018 at 8:30 AM
GEARBAG1
  • 5 POSTS
What do you need?
Jul 26, 2018 at 10:07 AM
DANNY L
  • 5,648 POSTS
Hello again,
Does this look like the Actuator you are talking about?
Danny-
Jul 26, 2018 at 11:43 AM
GEARBAG1
  • 5 POSTS
no the actuator is in the hub or part of the hub assembly.
Jul 31, 2018 at 7:10 AM
DANNY L
  • 5,648 POSTS
Hello again.
Okay, I will continue to look for it or any other information.
Danny-
Aug 1, 2018 at 3:39 AM
GEARBAG1
  • 5 POSTS
Did you ever figure out if I can swap out the front drive unit with a newer one and how new can I go?
Aug 1, 2018 at 10:04 AM
DANNY L
  • 5,648 POSTS
I will try to find out again tomorrow. Person I spoke to was not very knowledgeable (new guy). I will get back to you tomorrow.
Danny-
Aug 1, 2018 at 10:18 AM
DANNY L
  • 5,648 POSTS
Hello again.
I did find out out today that the years 1998-2004 front differentials are interchangeable. Does this help? Thanks again for using 2CarPros.
Danny-
Aug 2, 2018 at 9:09 AM
