Front drive shaft compatible swap/replacement
23,457 MILES • 2.4L • V6 • 2WD • AUTOMATIC
TLUCK
What vehicle is compatible for a drive shaft for the vehicle listed above?
Nov 9, 2019 at 2:42 AM
Unfortunately drive shafts are not plug and play on a large number of vehicles. Looks like the only other vehicles are Mountaineers from 10/19/02 to your model year of 2004.
If needed you can always get one cut to length and have your u -joints installed on it but these are readily available so worse case, you will just have to get a new one. Looks like they are about $200.00 to $250.00 US.
Nov 9, 2019 at 8:44 AM
