Front drive line
150,000 MILES • 6.4L • V8 • 4WD • MANUAL
GFFR57
  • 24 POSTS
Hey,
The front driveshaft from the transfer case to the front differential has some side to side movement in the slip shaft. This does not seem normal. Am I right?
Thanks
Feb 7, 2017 at 3:28 AM
CJ MEDEVAC
  • 11,000 POSTS
Normal!
That is, when it has been rode hard and put up wet.
The drive shaft should not have any wobble in it, it should extend and contract only.
I think it is time to get another one.
If you seldom use 4x4, for short periods, and it is not a lot of wobble, maybe you can get by a while.
Vibration might what you notice the most.
The Medic
Feb 7, 2017 at 9:08 AM
GFFR57
  • 24 POSTS
Yes, that is what I figured. Thanks for the help!
Feb 7, 2017 at 9:37 AM
