Front driveshaft area noise
150,000 MILES • 4.2L • V6 • AUTOMATIC
ERNIESPRINGER
There is a noise coming from the front driveshaft area. There is some play in the front differential output to shaft. I want to remove the front driveshaft and use my vehicle while the parts are coming in. Is there anything I need to do after the driveshaft has been removed or can I just drive it in two wheel drive or will it leak oil out the front?
Sep 10, 2018 at 7:12 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
You can remove the driveshaft and just drive in two wheel drive. The flange that mounts the driveshaft to the differential actually provides a seal so nothing will leak. Same goes for the transfer case. I have attached a tutorial showing how to remove. Hope this helps and feel free to ask any questions.Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
Sep 10, 2018 at 7:39 AM
