4wd not engaging. 4wd light stays on while shifted into 4wd high or low. Front driveshaft turns while in 4wd. Actuator pump works properly and shuts off after 2 to 4 seconds. Will the Actuator pump system act properly if the Actuator is stuck in the 2wd position? Fluid level is okay.
Why won't 4wd engage?
Jan 21, 2022 at 7:48 AM
