Front differential drive axle seal
61,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
ROBERTSR
the driver side front drive axle seal is leaking oil. is this a hard fix?
Nov 2, 2017 at 5:14 AM
  • 31,937 POSTS
Not all that hard to do nut the drive shaft needs to be removed, to do this the outer drive shaft nut need to be undone, this will be very tight, you will have to drop the ball joint and the tie rod end to be able to swing the hub far enough out to remove the drive shaft. you will probably also loose some oil so be prepared to catch that with a container.
Nov 2, 2017 at 4:59 PM
